can anyone help me out with some casting numbers? They are 2.02 but I need to know the combustion chamber volume there angle plug heads that have been ported and polished already they just need valves/springs/studs/guide plates
puckhead said:they are 64 cc chambers if i put them on a late model 1 peice rear block that is stock wuold that be to much compression?
puckhead said:340292
sled_dog said:for $40 the statement of pass is stupid IMO. Not everyone is porting all the way out. Or even porting. Sounds like it is a large port job that cuts into the pushrod hole, not something I'd bet 90% of the people here have or will be doing anytime soon.
Vortecs are nice but not the end all be all. personally I doubt I will ever run a set except where they came stock. I'd rather have Bowtie heads over Vortecs, if I'm spending $600 on heads I might as well spend $800 and get something better, and have better port potential. Vortecs also have the added cost of intakes that are more expensive then stockers and if you need to run an EGR, have fun with that. And the limited lift capabilities.
