on-board air
bandit
Ellensburg Washington
Im seting up a on-board air system useing a york compressor out of a 77 ford any one else used a york on there sb chevy i want to see pics of how to mount it and run the belt(s) any help or ideas would be great!!!!!!!
by the way i think il take tons of pics and then do a write up on it and put it on a webpage
AJ
Soon to wheelin spot near you
Project Harvey
This may help out: http://www.K5.rockcrawler.com
*<font color=red>under construction</font color=red>*
Cool deal! I'm trying to do te same thing, but keep getting bogged down with repairs...
These guys cater to Jeeps, but info is info when building this stuff: http://www.homestead.com/vj40yorkonboardair/index.html
Shoot, I know there's a guy that did a real useful write-up somewhere on the net on a 350sb with a York for on-board air in a K5 or K10/20/30, but the link is on my work computer (and wife just got home, so time to sign off...).
Keep us updated, and good luck!!!
Ratch
<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A>
**K5 - What more is there to life?**
Thanks for the info boys hey new york if you wouldnt mind when you go to work grab the URL for me please any others with ideas???
AJ
Project Harvey
cheap easy and still works!!!
<A target="_blank" HREF=http://www.geocities.com/spencerhut/truck/air.htm>http://www.geocities.com/spencerhut/truck/air.htm</A>
MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM!
Yepper, that's the one I meant...
Ratch
<a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
bandit,
you may want to search for some early chevy vans. they also used the york compressor. i was going to go that way but the accessories in post1stgen blazers are different. also the water pump is longer in post1stgen blazers. I just fabed my own. it's basicly "T" built from a 3/8 slab of metal. It bolts to the front of the cyl head on the passanger side. I'll post some pics later.
I also added a 3gal airtank in front of the gastank, above and a tad in front of the pumpkin. i had to(excuses, excuses) install a 2" body lift to fit it in. I am running stock suspension with a 2.5" block on rear.
I just finished my setup this weekend. I aired up my 33s in no time.
ARQ.
1-72 4x4 CST Blazer
2-71 4x4 CST Blazer
ya. fabbing up the bracket wasnt to hard. give it a try. that the only way you'll learn. its start to get fun after a while. good luck. its worth it.
Adam
a.k.a. Adrock
88 Chevy Blazer FI 383
"With great power there must also come great responsibility" -Spiderman
yea i didn figure it would be to hard ive many alt. brakets at work i guess ill just jump into it after my hand heals
AJ
Project Harvey
Just something i've been thinking about, could a smog pump be turned into a air compressor? Just a thought i have been beating arouund!stupid?
thanks
baldbandit
"Have you driven over a F@RD lately!!
No an air pump wont work they dont build enuff pressure. They do make a great crank case evacuation pump tho!!
Out of 100,000 sperm, YOU were the fastest??
never dealed with a smog pump so im not sure but iv never heard of anyone useing one
AJ
Project Harvey
