( on hold ) ord shackle flip kit 4" 1ton frame used / 4" hd lift springs front
sweetk30
Back to play nice .
in the back of your brain
anyone need these items ?
checking for possible sale soon . coming off my 1 truck and droping it down few inches and doing front hanger from 2wd flip kit style.
new thay are 200 shipped basicly.
i can do sand blasted bare steel and shipped for 150 obo.
this will be avalible around end of march early april when weather brakes as i will be working outside.
also have stock shackles i can toss in . or longer shackles for 25 bucks more from drop kit on old 2wd i had. some guys have used them with no problems.
4" front lift kit springs hd design thay are beefy. ride o.k. in 1ton. but heavy duty. 5 or 6 leaf i forget in each pack. thay hold my fisher hd snow plow up just fine when i use it. brand is ? ? ? got them used few years ago. no marks or tags and bushings gone so no color to refrence from.
no bushings. and just springs. would like 100 bucks local or meet n greet for gas money. shipping is 75-90 bucks a pair these days.
Check back with me when you're ready. I may be interested.
I'm really looking for the 2" or 2.5" flip instead but can't beat this deal so I may change some plans around for yours.
I'm looking at purchasing a shackle inversion kit for my 90k5. going to remove my 4in blocks from rear. Will this b what i'm looking for? not sure. Thanks for consideration.
It is if you're running a stock 1 ton 14FF with the narrow spring perches.
If you're running stock 1/2 or 3/4 tons, these flips won't work.
correction even if he got the 1ton rear flip. he would have to address the front hangers on the rear springs to narrow up to 1ton specs. this would be done with 1 ton hangers.
but to answer your question mine wont work for you. sorrry.
but read here for good fresh info. http://coloradok5.com/forums/showthread.php?t=282282
