Hey guys...need some help here..85 K5 with gm goodwrench 350 edelbrock 1406 ..all stock as far as i know. Got a dead cylinder (number 8) and I have checked everything i can think of..swapped the plug..the wire..cap and rotor..checked for crossfire...even took the hei dist off my camaro and tried it..still dead. At idle i can unplug any other cylinder and get a bad miss...but unplug #8 and no change. I know what your thinking...figured bad head gasket..nope...compression check came back good..(well so so..135lbs..all 8 are within a lb or 2 of each other). I rotate the motor over and valves open and close all the way, checked for broken valve spring and everythings fine. Guys im lost..it was running fine then come home from work one day and its idling like dogsh*t...wierd thing is..when i have it in gear (which ingition problems usually show up more under load) as i eas the power on its missing bad until rpm is around 1500-2000 all of the sudden picks up power like the miss went away. Heres the wierd thing..i did this with #8 unpluged and it acted the same..all of the sudden jumps like it picked up a cylinder. Guys..im at a loss...i can drive it and get down on it and it runs good..actually pulls pretty good..but at light throttle misses bad..shit sitting at a light is a terrible miss. I even thought valve timing but that would affect all cylinders not just one.. What am i missing??
