Have you tried disconnecting the sending unit plug near the tank - with it disconnected the gauge should peg one way, and then short the sending unit wire (purple wire, at least on my ‘89) to ground should peg it in the other direction. This should tell you if the problem is the sending unit or gauge.
Just did a little research, 3 O’clock is with it open and shorted to bare metal on the frame is Empty. If you have some resistors or potentiometer in the 0-100 range you could connect that to the plug and see what the gauge reads. Also check the resistance reading of the sending unit to see what it reads.Disconnecting pegs to 3 o'clock ... nothing I've tried brings it back the other way. But it does fall on it's own from 1/4 to E just hooked up normally.
you can save yourself all this headache and just leave it.
Mine read 1/4 when full then 1/4 when it was 1/4 or dropping.
Fill up, track your miles.
I’ve read the guages were not meant to read exact, to prevent people from running out of gas. So when your gauge read empty there was still fuel in the tank. Furthermore it stayed on full longer than you would think it should.
We are all so used to “modern” fuel gauge reading and even those function roughly the same as the old ones to prevent what I wrote above..
I've heard this, particularly in regards to an old Cadillac setup, but I don't buy it for anything else.
The gauges are plenty accurate. They are all 0-90 ohm resistance (so same level of accuracy) and from what I've seen on the fuel and temp gauges, when setup properly, will be as accurate as they can be without being digital. GM spent time and money to make sure they were reading "correctly" (thus the various resistors) and they don't spend money if it's not important. But there is a lot to go wrong on the stock setup that can affect how well they work.
When talking about fuel tanks, it's important to remember that not many vehicles have tanks that are perfectly square or rectangular...on the K5 31 gallon tank for instance, the lower rear is angled, so there is less volume in the lower half of the tank than the top half. The float will drop faster as it gets closer to empty, even though your MPG remains the same. The taper isn't huge, but it's there.
OP here is a step by step:
https://67-72chevytrucks.com/vboard/showthread.php?t=640615
Check the sender OHM reading if its correct its your resistor on the back of your gauge. Read this thread it will not get more detailed than this.
@Chief Brody
