Sent this off today. Let's see what Optima has to say.
Optima, 5/13/08
We have a small fleet of 8 trucks which we have been slowly changing over to the Optima batteries as new batteries are required. The first two batteries seemed to work fine, the third, a Yellow Top, was a disaster. It started losing it’s charge after 6 months. We checked the charging system and electrical system and all seemed fine. It finally gave out, lost it’s charge and would not take a charge. We ended up buying a battery from a local parts store as we needed the truck immediately. We had the Yellow Top replaced under warranty and put it in another truck. We had the same issues, 6 months and the battery would not hold or take a charge. Incidentally, the first truck is doing fine with it’s replacement battery.
I’m wondering if there are any quality control or design issues with your batteries? Optima batteries are three times the cost of regular batteries and are now proving to last only about 1/10th the time. Before I give up on Optima entirely, is there any explanation for this or plans to rectify the current situation?
Battery identification #s:
6216406517
SC34DU G7
Thank you,
