ORD/AGR High/cross/assist SOLD SOLD SOLD
JeffHK5
Cincinnati
Have a 99% complete hydro-assist setup that I bought for my last K5 and I never used.
Everything is new and for rigs with Dana 60 front diffs in a K5 , mine was a 78'.
Have:
AGR SB1 2wd steering box
AGR Super-P pump
Hyd. line kit
Surplus Center double ended ram (2x8x1.5)
2----3/4-16 RH heims
Full Off Road Design high/cross-over steering setup.
Kit has:
High/cross steering arms (5bolt)
2wd drop pitman arm
ORD DOM offset heavy drag link
ORD DOM heavy tie rod that I sleeved with 1 3/4" DOM for extra insurance
4-new 1 ton ends
Stuff not included : Arm studs/nuts as they're thread locked into my knuckles and cylinder mounting bracket or tabs as these are custom to just about every rig.
I was going to use the double ended ram for a balanced assist system , which I've had good luck with before.
Asking $1200 in Cincinnati or shipping on the buyer from 45252.
My rigs has evolved to the point that assist just doesn't fit under the front with the diff moved .
Pics of everything are available if anyone wants them.
Jeff
THIS STUFF IS SOLD!!!!!!!!!!
Yeah.. I don't know how or why that's like that .. Are they key words for sponsors here and automatically get a color change?
ORD & AGR
Would you split it up?
If so how much for just the pump?
BTW JeffHK5, where is Georega? :D
I can't split it up yet, I'll let you know if it comes to that...
That Georgia has been spelled wrong for like 3-4 years ..:crazy:
BTT for new price^^^$1100
And will also consider splitting the ORD stuff from the AGR stuff.
Off-road Design stuff
Pitman arm $60
High steer arms $250
Drag link with new U9016 ends $175
Tie rod with new U9016 ends $175
All stuff can be looked at here .....
http://www.offroaddesign.com/
All new + shipping from 45252
can i get a measurement on the draglink...and im interested in the pitman arm and pass side arm if he wants the drivers side.....
Jeff I sent you the money. My address should be in the email you receive from paypal. Let me know if you need it or anything.
Thanks,
Scott
