ord body mount kit
NEK5
3/4 ton status
Ipswich MA
It states it doesn`t include everything with it. What exactly will I need for it? I plan on getting their 1" body lift as well, so the bolts will be covered. TIA
It is 1" pucks and bolts only. If you need new poly body bushings you need to order that as a seperate item.
:doah: :doah: Sorry if I`m misleading you guys, my question is about the body mount kit, not the body lift....
Will I be alright buying the body mount kit and the body lift kit, both from ord?
Combined, will it include everything I need, or is there still more to it?
TIA
You will need to reuse the large cup washers on the 4 cab mounts, but other than that it will have everything...
better be prepared to cut holes in your floor...
Yeah, I plan on doing the cab mounts at the same time I do the floors over. So, the kit will includes the shims, spacers, etc? Just not bolts/nuts/washers/cup retainers?
If you get the body lift kit it will have the new longer bolts, nuts to go with it.
The body bushing Kit assumes that you will have the original bolts although we know that they tend to come out usinig destructive methods.
sometimes the nuts break loose and start to spin so you have to cut a hole in floor or the brace to get a wrench or socket on the nut. They are just spot welded in. This sucks when it happens, don't use a impact long breaker bar
