Posting this as these look great and I had no issues, sway bar disconnect has no interference. Probably the easiest thing I've ever installed on this bastard.
4.5 ORD bump stops
Honestly I'm trying for 2023.. I'll be so green out there trying to wheel this truck.so.... BB23?
Right out of the gate! BAM!so.... BB23?
Interesting thread. I'll either have to chance it or plan for other alternatives for bb23. The price of bump stops was a bit too pricey and I probably naively thought that these would be better than nothing, which they probably are just not ideal.You should cycle the suspension to see where those hit. They are kind of notorious for getting torn up.
https://ck5.com/forums/threads/lets-talk-bumpstops.294344/
Interesting thread. I'll have to chance it or not plan for bb23, unless I get some
more $$ for better ones these will have to do.
I did wonder after installing them, "what if they hit the U bolts on the axle"They can work ok but ideally they need to land on a smooth pad of some sort. If properly setup there is no reason why they wouldn’t last through a trip to Moab. I ran them for years.
Copy that...Find a loading ramp some place and back up it.....
Dude, totally crossed my mind. HahahahahUse the TJ fork lift lol![]()
