ORD crossover draglink gm vs dodge
newoldscottsdale77
Sykesville MD
Does anyone know the difference in length for the ORD crossover draglink for gm vs dodge. I have one off a k10 and a friend wants to run it on his late 80's dodge.thanks
IIRC the Dodge is about 1" shorter. I do know for sure that Chris from ORD can answer this one for you though.
The Dodge D60 is 2" narrower, so if it's a Dodge D60 under a Chevy the drag link would need to be 1" shorter.
If it's a Dodge D60 in an 80's Dodge, it's the same length as a Chevy with a Chevy D60 as the Dodge frame is wider.
