Is it common for the mounting feet on the 2 adapters to be different heights? I never noticed before but my doubler adapter feet are a good 2" lower than the stock adapter feet, I always assumed they were the same.
Am I the only cool kid with a Doubler?![]()
What adapter are you using?
As it sits the crossmember is on the OE adapter bolted directly to the frame and the Doubler feet are almost even with the bottom of the crossmember.
it's where it should be because I'm using ORD engine mounts and fairly new t-case mounts. All of the mounts are several years old but virtually zero miles and no wheeling or hot rodding that might have stressed them.
