I have some ORD shackles I bought used a while ago, then as I'm trying to install everything, I find out the previous owner bought them to fit a FUSH kit
So,
These are ORD 4.5" front shackles. They use a 9/16 bolt for the frame mount, which is used with an ORD FUSH kit. The bottom is for a 1/2 bushing. These come with the top 9/16 greasable grade 8 bolts. I will also throw in some used but in good condition poly leaf bushings. They fit TC leaf springs etc, rear eye of front leafs, and have a sleeve to match the bolts needed for the lower shackle hole. So... 3 things...shackles, upper bolts, and leaf bushings. You just need leaf bolts and an ORD FUSH kit.
The bushings are the ones at the top of the screen, right side inside the leafs.
SOLD
So,
SOLD
