Wait a sec...you actually go outside and wheel? That's just crazy!!
Rene
No, not really - I may be crazy, but not that crazy
. Today here in BTR, it was 34°C / 60% humidity / RealFeel (whatever that is...) of 46°C. Between beginning of May (= end of CruiseMoab) and mid-Septermber (= start of Blazer Bash), I just wait - wheeling season is fall-winter-spring
. Right now, my truck is in storage at single-digit humidity in AZ.
Actually, I'm currently trying to reign in/reduce the amount of suspension flex.
I'm of the opinion that two lockers beat suspension flex anytime, and that too much flex can actually make a truck unstable, particularly in offcamber situations.
While I've installed the greasable bushing setup quite a while ago, I found that at least in the Southwest, seized spring bolts/sleeves/bushings are not a consistent or recurring problem once the 20+ year-old stock is replaced with new parts (i.e. when installing lift springs etc.). The greasable setup has worked well for me, but I've also broken a front spring bolt - at the grease hole. I should also add that I'm too lazy/cheap to actually procure and use silicone grease for the PU bushings (you guys sure know that you're not supposed to use regular grease for the PU bushings, right?), so that might contribute to the split bushings. I've had a few bolts not cooperating in a grease job, but rotating the bolt usually helped. I haven't had a grease zerk pop out, though.
A set of new rear bushings is on my to-do list - the current set has no shoulders left...
