Does anyone have any feedback on the "ORD High Clearance HD Engine Crossmember" I'm in the process of putting a new squirle cage in my truck and i figured if it was worth it i would go ahead put this on there while i got the motor out of it. thanks
twoslo4five0 said:what are the limations of a staight one...i know BDAMNRZ runs a staight one he made out of a tie rod and it is no were close to his crossmember..i think he has about 9 inches of lift...he ran dle's insted of tre's cause the allow more movemnt for angle...what is the minumim lift you need to run to have a straight draglink with dle's??
so im running 7 can i get away with a straight one too??38377k5 said:He has 9" of lift, which gives him tons of steering clearance.
BlitzK5 said:was it easy to install the DIY4X motor mounts without moving the motor other then supporting the motor? Im looking to do the same thing, it just does'nt look like there is much room to remove the old motor mounts and install the new ones without lifting out the engine.
