So recently I got ORD motor mounts to replace the old stock ones that where trashed when I swapped my new motor in recently I went to bolt up the headers and the hit the frame could anyone suggest some headers that will fit with my new setup
Yup!@6872xtc did just this recently. Maybe he can fill you in. I know he used Sanderson headers
They are for some reason hitting the frame and not being able to like hug the block in the back I guess you could saywhere do they hit? ORD motor mounts keep the motor in the stock place. Just not the sagged place of the worn out ones.
Yup!
I did center dump style Sanderson so that I could eliminate the exhaust heat into the clocked t-case and fuel lines by crossing the right pipe over under the oil pan. These headers did make me buy heat sleeves for the center 4 plug wires.
Where do yours hit the frame?
My son put a set of Headmans on the SB in his '72 that are mid length and clear the shackles when compared to most 4 into 1 headers.
My Sandersons,
Hedmans
I had a set of lower level Hedmans, long tube, hit the shackles in a '79 years ago. The local muffler shop heated the tubes with a torch and made clearance. It worked for a beater, but a better fit would have been nice. He had just done an install on an '82, without a problem.They hit the frame infront of the shackle I have some random old longtubes no name brand or anything on them got them with the truck
Yup!
My Sandersons,
Hedmans
This seems to be an issue related to brands but not necessarily cheap vs expensive. Some folks trim the frame (I'm not a fan of this), I'd buy better fitting headers.
As far as long tubes vs short, there is a valid performance argument however how sensitive the motor is to the style of headers will depend on how it's built. A stock to mild motor probably wouldn't notice much difference where a more modified motor that can turn higher rpm probably would.
I want to say there's a thread in the Garage forum by @dyeager535 with part numbers for quality, good fitting sbc headers.
I can upload a picture of where it’s hitting when I get home from classes this is the last thing I need to buy/fix to get my baby running after a year and want to figure it out sooner than laterAs far as long tubes vs short, there is a valid performance argument however how sensitive the motor is to the style of headers will depend on how it's built. A stock to mild motor probably wouldn't notice much difference where a more modified motor that can turn higher rpm probably would.
Not my thread. https://ck5.com/forums/threads/hedman-elite-header-review.213472/
Agree that running headers is better than not running headers, and if you can fit them, long tubes are likely to be "better" than shorter, but there are so many variables it's guessing if you can't test them.
That said, there are some stainless eBay headers out there that are apparently fairly decent and very cheap (and a recent thread to go with), as far as I can tell impossible for the big names to compete with on cost.
we've had good luck with the hedmans here:
Hedman 69830 – Ceramic coated
Hedman 69230 – Painted, thinner flange.
probably what was mentioned earlier. They exit a bit higher than some, enough to keep them away from the shackle.
While on the topic of front shackle hangers. I got a quick question. Mine while bolted to my front leaf springs they don’t sit straight down they are a little diagonal is that normal/okwe've had good luck with the hedmans here:
