johnnychimpo
[FONT=Arial, Helvetica, sans-serif]*Update*
I ordered new metric bushings for my springs from ORD. They do not have greasable rear metric 1.7" bushings.(don't get your hopes up). I went to install them & were a really tight fit (had to beat them in w/ a mallet). After I got one side in, the fit was so tight I couldn't push the sleeve in because the hole in the bushing was so distorted. Anybody else had this problem if so what was your solution?[/FONT]
I followed ORD's instructions from their site on removing the old bushings in my rear springs (1990 1/2t Sub) : "[FONT=Arial, Helvetica, sans-serif]The factory rubber bushing consists of an inner steel sleeve, the rubber and a thin outer steel sleeve. The urethane bushings fit directly against the leaf spring so all 3 components of the factory bushing must be removed. There are several methods to removing factory rubber bushings. The safest is to use a small diameter drill bit to drill out the rubber around the inner sleeve until it is loose enough to be driven out. After it is out, the rest of the rubber can be "chunked" out with a chisel or screwdriver and the outer sleeve split and driven out. Install the new poly bushings with plenty of grease or anti-seize on the outside and inside. They should be a snug fit but shouldn’t need to be pressed in."
The new poly bushings are 1.5" in dia. My spring eyes are about .100 too big now that I removed the outer sleeve in the spring eyes. I spent about 3hrs beating/burning the living sh!t out of these. Anyone have any suggestions what I can do to make up the .100.
[/FONT]
[/FONT]
I'll give them a call. Thanks for the replies.
