CrpMag122
I am getting frustrated with this damn project. I am at the point where I am not even enjoying wrenching on something for the first time in my life. So enough whining, here is the current situation. I am running a 6" lift. Front is all spring from ORD, their springs (Alcan). Rear is a 4" spring and a 2.5" shackle flip, also all ORD stuff. I got the springs in place last week using the 4.5" ORD super shackle. I noticed right off the bat the angle of the shackle looked extremely wrong and was thinking the shackle would try to invert as soon as weight was put on it.
So, I called ORD, told them my concerns. I was told it would be fine and the weight on the spring would push the shackle back. They told me if it was an issue I would have to weld a limiting bar onto the shackle flip but there wouldn't be a problem dropping the weight down onto it. So, against my better judgement I gave it a shot. Guess I was right.
The minute I put the weight of the rear on it there was zero compression of the spring and the shackle inverted to the point where it was pinching up around the spring. Nice, I have a hardtail K5. I know I will need to call ORD again but I am hoping this something that can be quickly fixed and wanted to see if anybody else has had this issue.
I tried flipping the springs around to see if they were in backwards. Couldn't even get the eye bolts in. Measured the leaf springs and found out they are about 53" from eye bolt to eyebolt, measuring along the arch. Measuring across the spring eyebolt to eyebolt they were just about 47". To me this does not seem right. Seems to me with so much arch in the spring they should be longer then an inch above stock. Any input is appreciated.
