nimak5
I need help from the gang and couldn't get a clear answer researching. I'm getting started with my rear suspension and I've decided to run 56" springs in the rear with the ORD shackle flip and ORD Super Shackles. I currently have a 6 inch suspension lift with 4" blocks on a Dana 70HD 1 ton rear.
My question is which 56" spring, zero rate, ORD super shackles combo will get me the same ride height and most flex? I'd like to know if I should find stock 56" springs off a c/k 30 or go with 2"/4"/6" springs, superlift/rough country/tuff country EZ /HD? and what length ORD shackles?
Here is a pic of my current setup:
