I have another thread about this, but I want to ask here... I installed new ORD 4.5" rear springs on my K5. They replaced Rancho 4" springs. I notice now that my driveshaft appears too short - the slip yoke on the NP208 is sticking way out.
Doing some rough measurements, the old springs measured 25" from each eye to the center bolt. The new springs measure 26". I just used a tape measure and measured straight line distance so maybe this is misleading?
With ORD springs in the rear and Rancho on the front, the distance from axle level to body crease is about 2" higher in back. Again, maybe a misleading measurement, but seems like a bunch more lift.
Two other things maybe important: rear axle changed from 12-bolt to 14bff. The distance from axle centerline to pinion yoke measures very close, so it doesn't seem like this should matter. Also, installed ORD heavy duty shackles, which are a tad longer.
Any idea what's up? What can I measure to be sure the springs are right in terms of lift, length, axle offset?
