Recently received and installed a set of ORD custom leaf springs. The ride is much improved and it made the K5 way more drivable. I should have went with these springs 5 years ago when I lifted it.
The rear springs with the 4.5” HD shackle and 0” lift added 1.5” to the rear, but the rear was a bit low (43.5”)compared to the front (44”)to start with. That was measured from ground to top of fender well at axle. I expected the 1/2“ from the shackle, so net lift on the spring was only 1/2” had the rear been level with the front. Can’t ask for much better. Rear shackle flip was done 5 years ago.
The problem is that the front springs were spot on regarding lift compared to the EZrides I had on there, and…as advertised, they have more flex than other off the shelf springs. So now I get some rubbing when at full stuff. I had a tiny bit before and if I went slow enough I could avoid it. Now it’s Ez. I am thinking I should have chose the option to move the front axle forward an inch.
Question is, since the rear is 1” higher, what would you think of adding a 1” zero rate to the front and using it to move the axle 1” forward? I recall the ORD zero rate was capable of that. Any reason not to do that? Aside from a longer front drive shaft, still running the stock shaft, not sure how much extension is left in it, are there any other things I should be aware of when moving the axle 1” forward? Any idea if the springs will “settle”? I know they can lose arch via a regular beating, and over time, but shit, the stock rears were in there for 35 years and probably lost 1/2” at most.
