Nobody knows about the ATF since you deleted that post!I was confused as all get out where that front brace went. I sent ORD a rambling email much like my posts here.... hahahahahaha oh well. I figured it out.
I was frustrated seeing that atf, sent me into a downward spiral....
As others have said leave all the bolts loose while getting things lined up. A 2nd set of hands really helps to lift the box up and take the weight off while starting the bolts. I peeled out the first thread on 1 hole last time. Even with a helper. I was certain the bolt was in right, it wasn't. Fortunately the bolts are long and a quick chase with a tap fixed it. It can be frustrating to get it all lined up, no room to work up in there.@Wes Harden
Yeah, I was just holding it in place to get an idea.
Thanks for pictures. I’m installing that part today or tomorrow.
