84CUCV
3/4 ton status
right from ords site:
You may also want to check the condition of your swaybar mounting bushings:
Part#: BG05024 Price: $29.00 fits '73-'80 Buy Now[/FONT]
all new. bolted on but never used. disconnected and bushings. hoes $ 100 + ride
[FONT=Arial, Helvetica, sans-serif] Description: This is our premier product and the original GM swaybar disconnect system. It corrects by raising the back of the swaybar two inches to help compensate for a lift and also by adding a pivot point to keep your swaybar from binding up the front suspension.
The disconnect feature allows you to, well, disconnect the swaybar for a softer off-road ride and about a 50% improvement in front articulation. The kit is also includes a holdup bracket to hold the swaybar out of the way when it’s disconnected. The gain for your dollar with this kit is the best of any suspension product.[/FONT]
[FONT=Arial, Helvetica, sans-serif] Application: ’73 to ’87 GM fullsize truck ('73 to ’91 K5 & Sub)[/FONT]
[FONT=Arial, Helvetica, sans-serif] Part#: GU37001 Price: $99.00 Buy NowYou may also want to check the condition of your swaybar mounting bushings:
