F-ingrob
Wheres the mud
Can i order and pay using pay pal
And if im putting 52's up front of my 87 K5
Do i need the washers you sell
The zero rates are for the rearAlso consider having ORD cut the needed degree into the zero rates. That way you don't have to run a separate shim.
The stock front spring hangers which are already moved forward and I will be putting the rear shackels (on the front springs) back in the stock locationWe aren't setup with Paypal at this point.
What are you using for springs hangers for the 52" spring swap?
Dana 44What front axle?
