See my lastest post below.
Bought a lightly used set of ORD discos and poly sway bar bushings from combatmatt. I think I can figure out how to put this all together but would welcome any pointers.
There's a L shaped bracket that I assume you attach the bar to when it's free. Where do I mount that and in what orientation?
I like to lube stuff like this up when I install it so what sort of lube works for poly bushings? I normally just use never seize.
Thoughts/advice/pictures appreciated. Thanks.
