Last time I was under the truck, noticed one of the rear lower (axle) shock mounts had oval-ed itself out.
Is there a preferred fix? It seems "repair weld washers" would be ideal (like these https://barnes4wd.com/products/repair-weld-washer-5-8 ). The other option would seem to be buying replacement mounts. New mounts are cheap, but seems like a lot more work.
To me the repair weld washer on one side, with a nut welded on opposite sounds like the best approach. Way more meat for the bolt shoulder to ride on, no chance for movement on the nut side, and one-handed bolt removal.
What's the failure mechanism on these? I was told that the bolt being loose won't keep the inner sleeve in place, which can make it easier for this to happen. Used axle, for all I know the hole was already oblong before I got it and just didn't notice when I bolted the shock up.
Finally, not being where the truck is, are the bolts typically 5/8"? I presume they are whatever is correct for a later K5, that's what the shocks are for.
