Ok, so I think I've screwed this up, but need input/reality check to make sure that I'm not just being overly paranoid, or if this is a valid concern.
'79 K5 12-bolt GM rear end. I've replaced my rear driveshaft, beefed it up to a 1 ton shaft which means new rear pinion and transfer case yokes. Before taking off the rear pinion yoke, I marked the position of the nut to pinion shaft. It was on pretty good, so I had to take it off with an impact wrench. My screw up was momentarily hitting the nut in the wrong direction with the wrench (ie tightening and not loosening the blasted nut).
So, I have the new yoke now on the pinion shaft, and the scribe marks that I made prior to disassembly is off by one third revolution. I'm not sure what the thread pitch is, but I'm guessing that I've crushed the sleeve an additional 0.020-0.030 inch.
So, with all that said, do I need to buy a new crush sleeve and install the sleeve to set the pinion bearing preload?
Rich
Rich
