sniperthx1
My 87' V10 started leaking coolant out of the upper radiator hose, not sure whether it was an issue with the neck or the hose, gonna pressure test the radiator and make sure it isn't the radiator. Replace the hose too.
Anyway, being as I was in the mountains grouse hunting at the time, I RTV'ed the area and couldn't find any leaks at the area, so I got home.
However, as I was driving home, the engine temp would fluctuate between 210 and probably around 230-40 or so. Kept making me very nervous.
I also noticed a slight grinding noise when I would change engine RPM quickly. It would go away quickly.
I've checked the oil, (because I overheated the engine) to make sure I don't have any coolant in the oil. I don't.
Seems to me I shouldn't have overheating issues if I had solved the leak problem, but I did.
The temps I was watching were during highway driving. Didn't drive on the surface streets much.
I wonder what I should look into besides the radiator?
Another thing, every here and there, I can rock the truck bed back and forth and hear a clunk noise from the rear axle. Not really sure what to think about that. At least, I assume it's from the axle, I guess it could also have come from the transfer case, but I'm not sure.
I noticed this shortly after I caught air in the truck.....OOps.
Only problem with that, is it tears up the fuel mileage.
