I was mainly eluding to the fact that I didn't think 9.78:1 was considered really high compression.
9.78:1 is ALOT of compression with an iron head in a 6000lb. vehicle. If the heads were aluminum then you can get away with more compression but this isn't the case. Also, a 72cc head with a domed piston is going to net more than 9.78:1 compression. If he can give me specific numbers i can tell exactly what the compression ratio is. Highy doubtful though that he has all the required numbers to accurately figure it out.
Just checking with some easy numbers he's already looking at closer to 10.2:1 CR
