If you need to try an acid flush, just buy a new radiator. Outside of re-coring, you will never get all the junk out, and the tubes are already weakened from corrosion. In a hot climate, there is no reason to play around with a mediocre radiator. (FYI anti-corrosion is the reason to do scheduled coolant changes)
$250 for a radiator sounds ridiculous, is there a reason it was that high? Maybe I haven't looked in long enough, but last one I bought was under $150.
