oxy welding
eel757
south georgia
I now have way more respect for people who can oxy acetylene weld. we started oxy acetylene welding in tech school our instructor made it look easy....... it is way harder than it looks not only to get a good weld but to have it look perfect as well. its taken me 3 days and I'm finally getting okay at it. it makes me think of all the old school guys who only used oxy and how good they must have been.
Next try oxy welding aluminum.
Gus
lost art.... I don't do it often these days.. it's how we welded everything in the resto biz prior to MIG's getting real popular back in the day..
It is fun, i do all my light duty stuff with oxy-acet. I don't have much choice since i dont have a wire feed welder, just a big Hobart portable stick machine.
I learned with a stick then went on to mig and tig, I sure wish I knew how to oxy weld, it is on my list of things to accomplish, those electric devices would be worthless in a SHTF situation.
its my favorite type of welding:waytogo: Thats why i want a torch SO bad. besides all the OTHER good reasons to have one. I've found guys that have welded longer than me that dont even know it exists:rolleyes: they try arguing that im talking about brazing:haha: I've had to show a few older mechanics the difference. seems its been dying for YEARS:doah:
An art is deffently the way to decribe it I've been thinking about getting tanks instead of a nice machine
Another dying breed for sure. My old boss could braze almost show quality.
I used to weld with the cutting torch when I was in a hurry. I doubt I could make that happen these days.
Can't tell you how much stuff we did with oxy and coat hangers.
I cut my Royce Union bicycle part, rebuilt it as a mono shock. :woot:
It was either oxy or stick. Tubing was too hin for me to stick weld. And no grinning. This was in the early 70's.:doah:
yup, we'd weld with coat hangars back in the day in a pinch... nowadays ya can't they're all pot metal...
I've heard stories of using coat hangers to fill the gaps in roll pans I there's a lot you can do with it
I used to build a lot of old trucks and muscle cars "back in the day" (80's). The roller detent hinges were often left with no maintenance, and you would get the characteristic "groan-POP" often heard when opening and (particularly) closing the doors. Eventually they would fatigue the metal in the door bulkhead right by the hinge mount. The subsequent crack presented ever greater problems and had to be fixed or the door replaced before it would eventually (nearly) fall off. I can't begin to say how many I've seen like that. Sometimes you had to lift the door handle to get the striker plate to start onto the pin, particularly on the larger 2 door muscle cars with long heavy doors. Anyway, I've seen all sorts of attempts to fix them, few successful.
The best way I ever found was taught (well, more explained/advised) to me by a real old school body man from back in the days when led was in common use (50s and 60s) and many coats of hand rubbed lacquer was the norm on high end cars. He explained that the only way to fix it and have it last was to oxy weld it, and that the larger HAZ annealed the work hardened/fatigued metal so that it would be "good as new". He then demonstrated for me using the ubiquitous coat hanger for filler. Afterward I fixed many like that for me and others, never had one fail, though mine were never as beautiful and uniform as his. Of coarse you could anneal and weld, but the OA was just the ticket for that job, and could be done in most any home shop of the time.
Of course a large HAZ isn't always good, and that combined with the slow rate is ultimately responsible for the downfall of OA. I do miss it a bit, there was something a bit "zen" about the whole process. You had to settle into a comfortable (if possible) and stable position, nice steady hands, easy breathing, settle into a rhythm, and time just melted away (along with the puddle if you let your mind wander). Unfortunately my OA welding (like my GTAW) was more of a hot glue like affair, functional but usually not very "pretty".
