The 6.2 pump has two returns on the can and is probably set up for a remote reservoir (not a screw on cap on the actual pump, but a nipple for a hose). The flow ratings is also likely different since it was meant for hydroboost.
But in any case you could probably make it work. You can plug off one of the returns and figure out how to put cap on it.
