p/s pump pulley
6.2Blazer
3/4 ton status
Ohio
I'm looking for another pulley to put on a spare p/s pump (a failed pump means no steering, and no brakes). The trouble is nobody carries the 6.2 specifc pulley, and I can't find one in any of the local junkyards.
It's the two groove style, with one groove a smaller diameter for the A/C (which I don't have, but would like to use or OBA in the future).
Is there another application that would work?
You'll have to get one off another diesel. Take the pump as well because they are different:( The Hydroboost uses a stronger pump. From what I've read it's not a good idea to run a non-hydro pump.
I already have a spare pump...actually I have two spare pumps, but only 1 pulley.
I just hate to spend that much money (junkyards are the same price) to get a pulley when I don't need the pump also.
Thats cool, if I seperate them or find another I'll drop you a pm.
colbystephens said:
i didn't have any trouble getting a pulley for my pump.
Were you able to find the 2 groove pulley?? I just did some more searching and found a single groove pulley (w/o AC) for any older model truck, which I assume would work, but can't find any 2 groove ones.
the replacement i got was for a single belt b/c i'm not running an a/c and it was the only one they had in stock - but they said they could get a dual belt pulley if i wanted it, but time was more of a concern to me than waiting around for a 2 belt pulley. :)
Well I've got one but I used the wrong puller and it seperated:o:o Pulled right off the center ring. Looks like they originally pressed it on the ring and spot welded. If you are a decent welder you might be able to weld it back on. Only problem is I still haven't gotten the ring off the shaft which I need to do because I'm swapping to a single belt.
I'll send both parts to you for the price of shipping if you like.:dunno::dunno:
