P/S Slow and jerky?
max 02
Roll the dice…
Eckville Alberta Canada
My 77s Power steering is not happy, its jerky and slow.
Is that the box or the pump? The fluid is full.
vehicle off .
remove cap .
watch fluid and level .
have someone start the motor .
if no change then its the pump .
but by the sounds prob a pump .
Nice! I`ll try that tomorrow!
Got a pump or 2 hanging around...not positive if I got a 4x4 box though.
Got a 2 wheel one I`ve been saving for it.
Thanks! :thumb:
Check the belt tension and even check the belt itself. If the belt slips then you'll get the same symptoms you have.
Got a chance to play with it yesterday...turns out the belt was a bit loose.
Got my kid to start it while I looked in the pump, nothing funny going on there, just some nasty looking oil!
seems to be working good now.
doller store turkey baster .
1 qt p/s fluid and empty jug .
engine off suck out . refill .
fire up and turn left / right 2-3x .
re rain / fill till all new fluid is used .
good basic fluid swap out.
Good tip! Thanks!
I feel like a amateur over looking the loose belt. :doah:
Also the bottom bolt going into the block is striped so I cant tighten it,and it wont come out.
I`m just going to leave it for now, till I replace the engine.
For the win. :thumb:
