86 K5 blazer frame and 70 cab how much of a pain would this be? I'm pretty sure where there is a will there's a way, but my biggest concern is that I would like to use the blazer suspension points and bolt motor in stock k5 location.
Not totally necessary on a 78 and up k5 frame, but it helps. Swetty is doing this but made his own crossmember. The 73-77 k5 frames are different. There is no rear passenger footwell and the body mount in that location is different than later k5s but is the same as pickup cabs. Therefore, a 73-87 pickup cab will bolt right onto a 73-77 k5 frameI'm not sure,but I think you'll need the rear cab mount crossmember from the pickup, to mount a 73 -87 cab onto a K5 frame of the same vintage...
