CK5 Network
Become a member of the largest online community for Chevy K5 Blazer, Suburban and C/K series truck owners!
P30 chassis
yellowK20
Well Lubricated
Premium Member
Wasilla AK,
Was thinking about taking a P30 chassis and building a tow rig around it , using a squarebody or GMT400 crew cab and medium duty front sheet metal.
Does anyone know the spring pad spacing on the front axle? If it’s 32” I would swap a Dana 60 in .
sweetk30
I build stuff
Premium Member
horseheads , ny 14845
the 3500hd gmt400 is a weird spring width all to there own . not a std 32" or the ford width of 36.5" . if i recall its 34"
yellowK20
Well Lubricated
Premium Member
Wasilla AK,
I wouldn’t use a 3500hd frame ,
Just maybe a nice GMT400 cab
sweetk30
I build stuff
Premium Member
i think that motor home is on a 3500 hd frame maybe . thats why i said that .
if its still the old stuff then i got no clue . but a friend of mine years ago built a p30 box truck 14k gvw frame with a 73-87 cab / clip on it with few simple mods for a set of mounts as the frame is more flat and no hump to clear the floor of a truck cab .
rksjd8420
Premium Member
Roby Texas
I think the spring spacing is the same as the 3500HD too. They are between 33 and 34 inches. I have several 3500HD’s at home. I will measure one when I get home.
yellowK20
Well Lubricated
Premium Member
Wasilla AK,
I have no clue what that motor home has under it , wasn’t planning on using it .
I have access to a couple of other P30 chassis that are 8-lug but straight axle front
sweetk30
I build stuff
Premium Member
OOOOOOOOOOOOOOOOOOOOOOO
now it makes things more clear . . . . you talking motor home the last day or so and then toss this in the mix .
yellowK20
Well Lubricated
Premium Member
Wasilla AK,
Haha yeah , my bad
I think the motor home is 3500HD chassis it has the big 5-lug 19.5 wheels and tires
ZooMad75
#crawlabago
Premium Member
Pueblo, CO
Here's the quick rundown. First off a P30 or P32 chassis has always had IFS front suspension. It's basically the same setup as any C30 front end on a squarebody truck. They bumped the GVW up with heavier coils and later with air bags up front in the coils. It was the chassis that was sold to Workhorse in '98 where it continued along as the widetrack P32 where they pushed the control arm mounting points out 6" per side with a section of box tubing on each side so the front track width was the same as the outer rear dual tire. GVW got pushed up to 18,000 pounds in this form.
So if you want to stuff a D60 under one, it's no different for the most part than converting a C30 over. The frames are straight front to back so it's just a matter of making mounts to match whatever D60 you find for it.
