1-tonmudder
I have been working on my nephews 95 S-10 Blazer,When it came to me it had a bad trans and a busted heater core.I pulled the 4L60 and had it rebuilt,put it back in and drove it around for a day or so before tackling the heater core.
Since I put the heater core back in it will not keep a battery charged.I have had the alt tested and it tested good (14.5 volts) but it would'nt keep the battery up.Bein skeptical I put on a used one that also tested good(14.5 volts) and it was no better.It had a red top Optima on it that looked fairly new and I felt it was good but I was tryin to cover all the bases so I put a battery that I knew was good on and it did the same thing.With the engine running you can put a meter on the battery and watch it drop voltage as it runs.I undestand that it will do that since it's pullin voltage out of the battery and none is goin back in.It will run for 15-20 min before goin dead.The voltage on the alt post is/will be the same as the battery everytime.
Is there anything behind the dash that I could have missed that would keep the alt from charging???Seems awful coincedental that it happened after I had the dash apart.Any help is appreciated as he is coming Fri to get it.
I have checked them-several times.I went back out to see if it would start back.Turn the switch over and nothing,dash lights but wouldnt attempt to turn over,so I checked the voltage and the battery was 12.7 volts which I know is low but it should have turned it over.I put the Optima back on and it was 13.5 volts and it still won't do anything.I have had to peck on the starter before to get it to turn but I contributed that to a low battery.Could a bad starter be causing these problems???
