I've got a 15' Vanguard Banshee Mk2 that is in need of a transom.
I've done plenty of research on how guys are doing it. Haven't found much on banshees, but the glastron gt150 is slightly similar. Have found plenty on them boats.
I've read there's certain styles of exterior grade wood that is comparable to marine grade wood at a cheaper cost.
Also, quite unsure on what to use for epoxy, resin, fiberglass mat etc etc.
Finally, I don't plant to pull the top cap off the boat to do it unless I simply can't get in there to do it. I have read about guys doing it with the cap still on but it is a PITA.
Any tips on what to use, process's to try are much appreciated.
