Sold Painless Performance Products GM Truck Chassis Harness 1973-87 Chevy/GMC Truck 2WD/4WD
Tonyraca
Registered Member
San Jose, CA
I completely gutted and rewired my old 1979 Blazer awhile back. This harness made the whole job super easy. I got rid of that truck, but completely removed the harness before scrapping it. I didn't trim the wire lengths at all. Any extra length I just coiled up and zip tied so the full length of all the lines is still there. Everything is still there and just a bit dusty, but essentially ready to go. The whole kit retails for ~$800. I'll take $300+shipping or a reasonable offer.
Painless Performance Products 10205 Details
GM Truck Chassis Harnesses
Number of Circuits: 27 Fuses w/ Horn Relay & Maxi Fuse
Harness Length: Factory Fitment Fuse Type: Blade & Maxi Fuse
Firewall Passthrough: Bulkhead Connector
Color Code Based: Factory GM
Connectors Included: Ignition switch, headlight switch, dimmer swtich, wiper motor, blower switch, blower motor, blower resistor, instrument cluster and headlights, 10SI & 25 SI Alternator, HEI Power and Tach and 20 Extra 56 Series Terminals for use with any Factory GM 56 Series Connector such as Headlight Switch, Wiper Switch or A/C Switch/Blower Motor.
Circuit Designations: Printed on Wires
This harness includes circuits for:
Headlight Switch- Power to headlight switch. Power wires out of headlight switch to head light dimmer switch, tail lights, dash lights and park lights. Preterminated connector.
Dimmer Switch wires include power from headlight switch and power out to low and high beam headlights. Preterminated connector.
Wiper Switch- Power to wiper switch. Wires to wiper motor and washer motor.
Turn Signal Switch- Power into and out of your column mounted turn signal switch. Preterminated connector.
Ignition Switch- Power into and out of to fuse block (ignition, crank and accessory). Preterminated connector.
Brake Switch- Power into and out of brake switch. This includes a third brake light wire.
Courtesy Lights- Power and ground circuits for dome light activation.
Alternator- Charge wire and alternator field activation wires. (Most alternators can easily be wired up to this Painless harness). Included in kit is a high output alternator wire that allows you to use up to a 140 Amp alternator. Connector included in parts kit.
Horn- 40 Amp horn relay mounted to fuseblock
Radio- Harness includes constant B+ (for preset memory) and ignition hot circuits for any aftermarket or factory radio. Also included are two pairs of speaker wires.
Starter- Crank signal wire for starter solenoid.
Engine section wires including electric choke, coil power, coil to tach signal, oil pressure, engine temperature, and A/C compressor clutch control wire. HEI connectors included in parts kit.
Headlight section wires including right and left high and low beam headlights, turn signals and park lights. Preterminated connector.
Tail section wires including tail lights, brake lights, turn signal lights, fuel gauge sender, third brake light, and reverse lights.
Dash panel section wires including fuel, temperature, oil pressure, voltage, tachometer, speedometer, high beam and turn indicators and gauge illumination. Preterminated connector.
Door section wires including power windows and locks.
A/C Heat- section including preterminated connectors for blower switch, blower motor and blower resistor block.
Accessory section wires including cruise control power, power antenna, electric fuel pump and a cigarette lighter/accessory output.
Also included in kit is a 4 & 7-inch zip ties, 70 Amp maxi fuse and a large assortment of crimp style connectors.
Specifications:
Type27 CircuitCircuit Quantity28Fuse Block IncludedYesFuse Block LocationFrontFuse StyleATO/ATCIgnition Key LocationColumnQuantitySold as a kitHarness LengthStandardManufacturer's Part Number:10205
Great price...wish I didn't have so much else going on.
Interested. How long ago did you get it and think it will fit in a medium USPS flatrate box or step up to a large?
I just happen to have a large box sitting in my desk at work. Let me check when I get home today and I will let you know.
