Ok guys I have a question. I'm doing a painless wiring install and would like for things to look original. How is the engine harness routed behind the engine?
Is the harness just laying across the top of the trans? The old harness was so hacked up and was just laying behind the engine! Tried lookin for an image that clearly show but nothing has come up.
there was spark plug wire / wiring combo clips and they clipped in to the stock vavle covers or tabs mounted on intake bosses . the wire loom the wiring was in was clipped in to these to held them and let it float around the back to the pass side .
The main thing with any harness is to keep it from chafing. Not letting it run on anything. The vibrations generated will eat a wire up quick. External sleeving and insulated mounts are needed.
Doing a full truck rewire, I would order a miscellaneous sizes package of insulated stainless steel cable clamps.
Hey guys I'm to the point of wiring the transmission it's a 700r4 w/ lockup. I need to wire in the power wire but the old harness was not hooked up when I got the truck. What one is the lock up switch and what did the wiring look like so I can search for him my mees of and old harness!
