painting a hard top
chevyjeff
WYLIE TEXAS
going to paint the old hardtop next weekend. going to pull it of the blazer and use a roller and a rattle can /forums/images/graemlins/pimp1.gif
what paint or coating have you guys used to paint yours?
I am looking for a low gloss black finish that will stand up to the texas heat
[ QUOTE ]
low gloss black
[/ QUOTE ]
[ QUOTE ]
texas heat
[/ QUOTE ]
Not to be a smartass or anything... But you're basically proposing to put a solar oven on your K5.
Anyhoo, if you want the finish to be smooth (probably not, since you're using low-gloss) you'll need to smooth the surface of the top. Scuff-sand with 220-grit paper, clean real good, then apply a couple coats of Bondo to smooth it out. Sand, prime, then paint to your heart's content.
Here is a close up pick of my hardtop that I rattle canned flat black.
And here is one from the rear. You can see the color that the top used to be on the lift gate.
/forums/images/graemlins/waytogo.gif
As you can see from the inside color, I have not had a chance to take the top off to paint the inside yet. It has held up well for the last year.
[ QUOTE ]
[/ QUOTE ]
Wife came up with our two hour total painting solution. Left hard top on, cleaned very well several times, taped & draped with Visqueen. Used a sponge, the Wally World rattle can automotive paint was sprayed directly onto the sponge, then dabbed on. One initial application with a follow up second coat two days later made for a durable pseudo baked hard finish. ( 100+teens ambient here in AZ desert)
It did a great job & looks gooood, for as we all know, the crinkly FG finish is not finicky.
