Painting interior pannels
TommyD11730
NY
Guys I'm looking to change my blue door pannels to black. What's the best solution to wipe them down for prep?
Same goes for the paint. Automotive or Krylon for plastic.
Thanks!
I used SEM it is pricey but people say it is worth the price. They have a full line of products for interior color changing.
There are also plastic-specific primers. I don't know the SEM products as my truck isn't, erm, show quality :haha: When I did my panels I just used the Krylon and such from the local Ace.
One thing I can offer is that, as with all things paint, it's all about prep, prep, prep. Surface condition is key. In my case, I had mismatched door panels, so I got a junkyard pair that matched ... but apparently had been stored three inches from the sun's corona. :doah: I spent considerable time lightly sanding them until the gritty outer sun-damaged layer came off. Then it took several light coats of plastic primer before the surface was nice again.
Since then I've had a bit of flaking, on the corners where I didn't sand so much and in spots where grease and dirt had accumulated. The lesson there is surface prep, and degrease, even with just like water-down 409 or the like.
I also found that the spots that flex, in my case by the window cranks, and maybe the pulls, are prone to cracking. Extra prep and careful application of the final coat (color or in my case matte clear) is prolly best there.
Pix and more rambling on my build thread @ https://ck5.com/forums/threads/74-k...to-why-you-do-that.209791/page-9#post-3016041
-- A
One problem I have had with painting interior panels is the paint wearing off where I touch it a lot with my hands or arms. The area around the door handle would wear right through the paint to the panel plastic because of reaching for the door handle to open the door.
Thanks for all the thoughts and suggestions.
I've used the SEM with success following all the reccomended steps.
It will wear off after time, especially when you wear sun screen.
