G-Force8
What up
I'm finalizing everything that I will need to have at my disposal when I do the axle swap and 6" lift on the 'Burb at the same time here in about a month and I need you guys' help to offer up any advice on a tool or part I may be overlooking.
So far, here is what I have.....
Front Suspension
- New 4"TCI ez-ride springs
- ORD zero-rates + 1"longer U-bolts
- old 10-bolt spring plates
- ORD greaseable main-eye kit
- ORD HD greaseable shackles
- S.S. brakeline kit (10mm to reuse my 10-bolt calipers on the D44)
- shocks (undecided, will purchase a set at Truckfest this weekend)
- Ford F-250 shock towers
- bumpstops (haven't ordered yet,but will either be ORD 'stops or Daystar)
- raised steering arm
Rear Suspension
- ORD 4" shackle flip
- ORD 6.0 SuperShackles
- stock 56" rear springs
- ORD greaseable bushing kit ( 1.5" main eye, 1 3/8" shackle end...I hope they're the right size!!)
- ORD zero rates
- shocks
- bumpstops
- ORD 14BFF conversion kit (U-bolt flip,conversion u-joint,shock tabs)
Axles going in
- '76 k20 Dana44HD/14BFF (4.10's, rear Gov-Lock)
Tools I have that I suspect I'll need
- (2) 3-ton floor jacks
- (1) pr 3-ton jackstands
- (1) pr 6-ton jackstands
- Harbor Freight 4.5" angle grinder, 10-pack of cut-off wheels
- 9.6V cordless Rotary tool
- short-drive 8pc punch set (for driving out factory shackle bracket rivets)
- assorted sockets and wrenches
- rubber mallet
- dead-blow hammer
- a .50cal revolver with a single round if all else fails!
I'm still waiting on a set of 16.5" wheels that I'm getting in a trade to fit the 35x12.50R16.5 TSL SSR's I already have and I assume I will probably be using wheel spacers since the 5" of backspacing is just a tad more than I want. I haven't decided on what type of brakeline I will use to replace the 14BFF's hard-lines,but I'll get on that soon. More than likely this will all hopefully be done in a single day,but possibly over a weekend. Will also be installing an ORD 1"body lift with new poly body bushings.
Just want to make sure I cross my T's and dot my i's and don't get stuck not having the right tool or having a wrong part thats impossible to replace in a short amount of time
This truck is my daily driver!
Any pointers to make things go easier guys?
Thanks in advance
Front Suspension
Rear Suspension
- ORD zero rates
- shocks
- bumpstops
Axles going in
- rubber mallet
- dead-blow hammer
Thanks in advance
, we'll see
