I can get pics tomorrow. Most of these mount with screws into the inner rockerAny chance you have a pic of how they mount.
Ship flat rate?
Ship flat rate?
That's what I have seen also.Most of these mount with screws into the inner rocker
The ones at LMC are just under $200 and I'm sure shipping isn't cheap either. Also they're not the factory ones that bolt to the leaf spring plate. After looking at them it looks like they need additional brackets to make them work anyway.Only if you call my property a scrap yard. I have a couple sway bars laying around but shipping to NJ won't be cheap due to size and weight.
These are unusual. Only two bolts through the lip of the rocker used to clamp them against the inner rocker. I won't be sure about shipping until they are removed but they may fit a large flat rate.That's what I have seen also.
In fact I have a couple pair of ones that do also. A few more years I'll be needing them on all my trucks probably.
Still interested if you could show some unmounted/backside pics please.
I think you would be in the range of $200 shipped with the brackets and hardware included.The ones at LMC are just under $200 and I'm sure shipping isn't cheap either. Also they're not the factory ones that bolt to the leaf spring plate. After looking at them it looks like they need additional brackets to make them work anyway.
I think I'd rather have factory. Let me know.
I'll have to check it again.Is the heater control assembly fully functional? I need another one after breaking the last one I bought from you...
