Parting 1983 K20 diesel pickup
How much for the guages and bezel on the diesel. How is the under dash harness on the truck? How much?
I could do $60 shipped on the cab wiring if its in good shape. I need to crawl under and look at it closely to verify it is in good condition yet.
$35 plus shipping for the dash bezel and guage cluster. The bezel is for an AC truck.
Okay well dibs on both until you find out if the wiring is decent. Even if it needs some repair that would be okay as long as the price came down accordingly. Let me know how it looks and I'll do one payment for the both of them.
How much for the Hydroboost pedal asssembly?
I'd take $10 for the auto pedal assy on top of everything else, it's mainly going to add to shipping costs though (weight/size). I'll double check the wiring when I tear into the truck tonight.
What is your zip code?
Hmm.... Well I already have a pedal assembly for hydrobell/hydroboost so I am good there $10 sounds great.
Wiring looks questionable in the cab at this point. We are going to tear the cab apart tomorrow so I'll find out more when we get into it.
The pickup is coming apart nicely. Front clip is off and the cab will be getting stripped and cut up tonight. If you want anything speak up now before it is scrapped.
emblems
I would like the front fender emblems off the truck if they are sierra classic emblems(looks like they are). With the clip off you can get to the nuts on the back side. How much...shipping to spokane?
Thanks!!
moldings
Oh...also the molding that surrounds the back of the cab underneath the rear window...all three pieces.
Thanks again
The trim behind the cab on the ends is actually dented and I got careless with the sawzall before I tried to pull it and screwed up the middle piece :doah: So I'm thinking $25 shipped for the fender badges and I'll throw in the two corner pieces if you want them. Pics to follow shortly.
I think the cab wiring harness is going to be ok, there are a couple cut wires near the radio. I think it was the hvac control wires. I can drop the price to $30 on the cab harness. I don't want to go any lower than that just due to the time it takes to pull it out.
That would be $80 plus shipping. Shipping will be around $20 via Fedex Ground.
