70BlazerX2
I have here one ugly 73 chevy that has seen better days..It did drive under its own power,after i fixed the firing order that the last owner did not fix..it was backfiring through the carb,bad..#6 and #8 were crossed..fixed it,rans 100% ..its a 1972 Camaro/chevelle 402 big block..lol
The trans is a turbo 350 rebuilt recently,dont know miles on it,Drove it here,shift kit..and shifts all 3 gears and reverse.
Has a 203 case with kit for manual hubs..all works fine..lo,lo loc,n hi hi loc
front axle dana44 flat knuckle..$200 complete i will check ratio soon
rear axle 3/4 semi float..$200 complete ,i will check ratio here soon
Tires 33 12.50 15's scorpion's with a good 5/8 inch tread left on all 4 $150 for all 4 (if you want 4 6lug 15 x 10 black nascar style rims add $100 )
Front drive shaft..$75 shipped (include shipping)
Rear shaft..$50...i will need your zip to check shipping it..due to size.
Body is shot..If you need spring hangers...body mounts..ect..just holler and i will cut them off..for you. I am in Greeneville TN 37745
its in sad shape..
