Parting 83 Diesel K5
Both metal fuel lines for LP/IP, the two that run in the valley under the intake.
Pitman arm
Fuel tank sending unit?
Depending on the shape of the lines/sending unit. If they're bent/kinked/pinched, etc.
Toss me a $.
The lines are trashed. Pitman arm is gone. The sending unit will be available in a week or two once I have the cab off.
Do you have the plastic insulation panel that covers the evaporator/heater box? I'd like it if it's in good shape. I need a fan shroud too. Just the main part that goes around the fan.
The fan shroud is gone. I have the panel from over the evaporator, but it is in bad shape
I still have the front and rear driveshafts, Front and rear bumpers which are actually in good condition, NP208, exhaust, other than that there's not much left.
If it doesn't go to him I'm interested. I need one for the DP build mine has a hole in the switch.
Didn't even to think to ask about that :doah:, I'd have taken the hole in your switch over mine sticking in the up position. Long story short it let all the smoke out :rolleyes:
As far as the sending unit, think I'll go brand new instead. I'm also switching to the 3 line instead of the 4 that 83 should have. Don't wanna drop that thing again anytime soon in case that used one decided to fail.
Guys, unfortunately the truck is gone. Some stuff was picked off by craigslisters. My buddy finally got tired of random people coming by his shop and took the rest to the scrap yard. All I have now is the frame and part of the cab, which is what I wanted. My ticket to a smog free vehicle. Gonna start swapping my drivetrain over this weekend
