Parting 85 GMC Jimmy
clarkjw24
McBee, SC 29101
1985 GMC Jimmy. 305/700r4/208 3.08s autohubs, a/c, power windows 31 10.50 15s. Rust holes on the top of the cab, bondo in the hood and passanger door.
Price list:
Steering column $75
Rear seat $40
vinyl rear side $100
drag link $45
$75 for just engine, $125 with ALL accessories and brackets (runs, but needs a cam)
NP208 T-case $100
NP208 shifter housing/console $30
factory driveshafts $100 both
Radiator $35
Factory Radio $30
2" receiver $40
gas tank skid $30
52" rear springs $30
Dash cluster $25
Badges, push pads, tail lights, 700R4, grille, headlight buckets, light harness already spoken for.
Anything not listed just ask.
Is the speedo cable the screw on style at the tcase? if so how much would you like for it if its still in good condition?
PM sent!
Cruise control unit on motor (rear engine behind valve cover) the bracket, part that mounts to the throttle link and stud, wiring harness into it and the module under dash on column.
Like all this with out the vac ball!
I may also be interested in the Power window and lock harness. Have some interest in the rear side panels too.
The cable is the screw on style, but I don't know what to ask, they can't cost that much new.
Hey if you have a blue driverside working seat belt? how much?
By working you mean pull out and retract? If so yes, but they're missing the plastic cover on the male buckle part.
PM sent!
That picture shows the column control also. I've got no problem with the rest but I not going to pull that from the steering column. I don't even know if this truck has cruise, guess I'd better check.:doah:
What do you want for the seatbelt shipped to 21918? Yea thats what I men pulls out and goes back smoothly thanks
Never heard anything back what happened?
i am looking for the rear seat mounts the part that goes in the floor in the rear, the rear seat belts. Also are the rear springs in good shape
Spring decent but thats going to be high shipping. So you would need me to cut the floor out for those latch mounts?
how much for the in dash ashtray assembly (door/ashtray/lighter) ? and also if you have it the hood latch release cable? shipped to 87121
The drivers side rear panel looked really good. However when I pulled hte passanger side it looks like it got a little wet on the foward side. If your still interested let me know. Also would you want the ash trays and speaker grilles and the little bottom carpet pieces. I've got all the screws and stuff also. $75 shipped.
Here are the seat belts. They work, just missing a few pieces of the buckle covers. Working gas guage also. $48 shipped.
Drivers side.
Passenger side.
