Parting Out 1978 K-30 a few items left
POFF
San Diego, CA
I have the following items from a 1978 K-30 GMC:
TH400 - $125
NP203 - $125
TH400 to NP203 adapter - I'll throw it in if you by the T-case and tranny. I do not want to sell it seperate until the tranny and t-case are gone. I want to give the person who buys the tranny and t-case together first shot at it.
Crossmembers - $20 ea
T-case skid plate - $20
'81-'87 Hood - primered with surface rust but I do not see any body work - $25
Stock rear springs - $25
Springs come with shackles.
T-case shifter - $20
Hump for column shift automatic - $20
A/C heater box - rough but useable - $20
Hydro boost with p/s pump, the hoses are shot - $50
Two tilt columns - pretty rough - one has a popped ignition - 2 for $25.
Sheet metal piece that goes under the grill and holds turn signals - has a small dent in the middle but looks fixable - $20
Steering box - $40
Gas tank filler tubes for dual tanks - $20 for both
Front sway bar - $25
Core Support - $25
I have a few other misc. parts, A/C vents, one front bumper bracket, charcoal canister, gas pedal assy., ash tray, rough glove box, wiper motor.
The truck was not running when I bought it so I do not know what works. I bought this truck for the front Dana 60 for my '70 so I do not know much about '73-up trucks. I tried to be as honest and accurate as possible. Please feel free to ask questions, I can send pictures if necessary.
The large or heavy items are local pick-up only, the small stuff I will ship. I will ship the cheapest I can between USPS flat rate and FedEx Ground. The heavy and big stuff is cheap because I don't want to ship it. Make me an offer!
Calling dibs on the skidplate and 6" front springs. Can you get pics of them up first?
pics
The spring pic is not very good. If you want better ones I will drag them out tomorrow after work and snap a few pics. The skid plate mounting holes have been used without washers so they are a little worn. The springs are too heavy for me to ship so you have to pick them up, the skid plate can probably go USPS flat rate for $8.10 (or what ever the going rate is).
The springs will ship easily. I've shipped and bought quite a few, so, its no problem with UPS.
I'm more interested in the height of the springs. If you can measure the arch by standing the spring up on the eye-bolt ends and measuring to the center bolt at the tallest part, I can get a better idea.
The skidplate I will pass on as I have too many of those.
I measured the springs. If I lay them upside down they are 6 1/2" from the center bolt to the ground on the top side and 9" from the bottom side.
