readymix
3/4 ton status
Updated December 4th-- Make offers on what you need
The engine has been removed and stripped. If anyone needs small parts, like vacuum lines post up. They are all good.
Chevy 305 TBI -- Taken apart, some of the good parts are listed below
1 - 39.5" IROK (new never driven on) $250.00
1 - 8 bolt HMMWV wheel
Miscellaneous:
- TBI unit
- Intake
- Double roller timing gear/chain set, about 1000 miles on it
- Harmonic balancer
- Emissions stuff
- Starter
- Alternator, has condenser added to cut down on electrical noise
- Brackets and hardware
Miscellaneous:
- 4" lift rear springs, no bushings
- PERCO disconnect and 2/0 wiring and remote starter solenoid, bulkhead mounted power poles $150.00
- Interior trim pieces (A-pillar, trim above windshield, and above doors, no B-pillar)
- Visors
- 1/2 ton spring plates, front and rear
- Fuel pump relay
- Throttle cable, in good shape, not worn out
- brake master cylinder and vacuum booster
- Windshield with built in antenna and harness for connection to radio. Has blue tint across top
- 14FF spider gear set $60.00
- Factory D60 diff covers (x2) $10.00
- wiring harness
- Manual window doors, complete with all glass
- Non-AC heater core, enclosure, and control head
- Manual floor vents
- Taillights
- Gauge cluster
- rust free cab floor, had to cut out the pass side rear mounting bolt since the nut was rotating. If you need a specific section send me some pics and I'll cut out what you need.
- Complete rust free firewall. If you need a specific section send me some pics and I'll cut out what you need
- Steering box area of the frame has been cut off and I will save it until someone needs it.
- Complete rust free cab back wall.
- Complete rust free bed front wall.
- Complete working tailgate with hinges.
- Blower motor and housing
