parting out '85 k30
muddybuddy
1 ton status
Northern, VA
im parting out my '85 k30 project to help pay for a better daily driver. the drivetrain and powertrain are already posted in the other sections of the classifieds, but the rest of the truck is up for grabs to. its got a complete '91 front clip with a NEW core support. the truck is non-ac with manual doors. fenders are in decent condition, doors are alright, cab is rusted, the best is alright. post up if you need anything and ill let you know if its got it and get you a price. ill get pics of the truck as well.
If it is a Big Block truck, do you have the radiator shroud and the mounting brackets for the radiator?
Thanks,
Tim
Thanks,
Tim
the truck has a 6.2, it might be the same as the big block, i work at a parts store, ill check tomorrow and see if the stuff is the same
ohh a 6.2? do you have the oil cooler lines? specifically the lower hard line that crosses the radiator and the upper hose?
i do have the lines, they come out of the radiator easy, but not sure how easily they will come out of the block, but i havent really tried.
Thanks,
Tim
i believe they are the same. if by radiator shroud you mean fan shroud, that thing is toast. ill check to see if ive got the mounting brackets for the radiator.
Thanks for checking it out, but the main thing I wanted was the shroud and I think they are different. The diesel radiator is wider than a 454.
Thanks,
Tim
no problem.
im going to try to get some pics of the truck tomorrow before i go to work, so ppl can post up what they need/are interested in and we can go from there
